Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint TDC60
- This topic has 12 replies, 5 voices, and was last updated 19 years, 5 months ago by
net0519.
October 30, 2006 at 8:14 am #22115
net0519
ParticipantIve got some problem with my dryer – when i turn it on it starts drying and heats up the drying light is lit, then it goes into the tumble without heat but then it dosent heat again and the drying light dosent come on again, its then just spinning and not really drying the thermos havent gone because i get heat at the begining but it stops after a short spin. Any ideas? 😥
October 30, 2006 at 11:16 am #193710iadom
ModeratorRe: Hotpoint TDC60
There is another thermostat, hidden inside the upper door frame that can cause this, plug out if you intend to have a look.
October 31, 2006 at 9:15 am #193711net0519
ParticipantRe: Hotpoint TDC60
Ive located that part, How do i know if this part has gone and what is the reference to get a replacement?
October 31, 2006 at 10:42 am #193712iadom
You have to use the correct electrical test equipment to check it, it can sometimes fail intermittantly so it may appear to be fine when cold, this is also true of the stats above the heater. There could also be a fault in the timer, not common but it does happen.
Part number for door stat is 1701575, an e-mail to spares@ukwhitegoods.co.uk should do the trick.
November 5, 2006 at 5:32 pm #193713satcom22222
Hi m8 sorry to trouble you but do you have any opperating instruction for the tdc60 as i have just brought a second hand one with no instructions i am willing to pay if you could send me a copy
regards
Satcom22222November 5, 2006 at 5:49 pm #193714Penguin45
http://www.theservicecentre.co.uk/Service/inst.html
Is what you want.
Penguin45.November 5, 2006 at 8:09 pm #193715satcom22222
Your a star thank you so much
regards
satcom22222November 8, 2006 at 12:58 pm #193716net0519
Have changed part,(door stat), Must not be that as still seems that its intermittingly cutting in and out any ideas?
November 8, 2006 at 3:56 pm #193717iadom
Difficult to guess from this distance. Mains temp control stat could be at fault but it rarely causes this complaint. Small copper brush that runs on top of drum can have dropped off, worn away or lost contact with the drum. There could be an intermittant fault in the dryness module although again the usual fault on these is the heater relay sticking on rather than off. Due to the cost of this module I would suggest getting someone to check it out first. Try the link in my sig to see if we have someone who can help. Plug out at all times when you have your hands inside. 😉
November 11, 2006 at 12:55 pm #193718net0519
Ive checked inside and the brush is incontact with the drum and is running ok.
It seems to be the white box behind the led lights which im assuming is the timer, i can hear something clicking like theres a loose connection sort of thing but ive checked the connections and appears fine, any other ideas as i would like to repair myself if i can..November 11, 2006 at 5:13 pm #193719bobokines
Have you checked the earth strap at the back of the drum bearing?
Bob
November 13, 2006 at 8:52 pm #193720net0519
No i havent checked that, how would i go about finding that and how would i know if thats the problem?
many thanksNovember 13, 2006 at 10:49 pm #193721bobokines
At the back of the machine there is a small square cover that protects the rear bearing, held on by two screws. Inside this cover is a small copper contact that supplies the earth connection to the drum. Make sure that this is in contact with the drum shaft.
The earth connnection supplies the return feed for the electronic dryness sensor.
Bob
