Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint TDC60 (changed thermostats)
- This topic has 21 replies, 6 voices, and was last updated 21 years ago by
admin.
March 22, 2005 at 7:12 pm #8632
KeymasterI took your advice and changed the thermostats on my hotpoint tumble dryer and the heat is now back on, But the active light is still on constant as it was before, whats causing that any ideas? Also when the heat stopped working there was a slight burnt smell now ive replaced the thermostats its still coming out a little bit but not sure if thats just from before and the heat is bringing it out . But the dryer appears to be heating normally.
March 22, 2005 at 7:34 pm #129733iadom
ModeratorRe: changed thermostats
Is the active light on even when the machine is plugged in but not in use?
A slight burning smell just after working on the dryer could be disturbed dust or fluff burning off on the elements. It should not persist for more than a minute or so. If it does, then after removing the mains plug check for lint or fluff build up around the element and if possible use a vac to clean it. Take great care near the elements, they are fairly delicate. It is not a bad idea to remove the top at the same time and vac out any fluff that you can see. Getting further into the machine to clean is not something that you should really attempt yourself.
March 22, 2005 at 8:00 pm #129734admin
KeymasterRe: changed thermostats
yes the light is on when i turn the dial to any other position but off before i even start it, but in the last couple of minutes ive tryed it again and how it was heating again after id changed stats now it seems not to be again! Has something made them break again?
March 22, 2005 at 8:31 pm #129735iadom
Could you clarify which button you are calling “active” do you mean the ‘drying’ neon. If this is on when you say it is then this is a fault I have encountered, once and it was caused by a faulty control (dryness) module keeping the heater on all the time. The heater should be disabled when the drum rotates anti clockwise. If the stats have failed as quickly as this then it sounds like job for an experienced engineer. I will check on the price of the module and post back.
This module is approx £70 + vat. If the appliance is under 5 years old a call to Hotpoint to take advantage of your 5 year parts g/tee is the best course of action.
March 22, 2005 at 10:48 pm #129736admin
Thanks for your information on my problem, there are 3 lights on my dryer
1. Active
2. Drying
3. Empty water
I do apologise it is the drying indicator which is stuck on at mo not the active, the active is lit when on but the drying one only usually comes on when its got the heat coming through then it goes off for a few seconds on a cooler spin but at the moment the drying light is constantly lit.March 22, 2005 at 11:12 pm #129737iadom
Time to call in the experts, almost certainly a dryness module failure, this would account for the rapid stat failure, the heater is on even when the motor is not running and when it is reversing.
Because the fans in this machine only ‘blow’ in a clockwise direction, the heater should be switched off when the drum runs anti clockwise for a short period to help prevent tangling.
March 23, 2005 at 12:38 am #129738Penguin45
ParticipantWithout the model number and serial number we’re guessing here chaps.
Guest, if you would be so kind…………..?
March 23, 2005 at 9:06 am #129739admin
the model is hotpoint tdc 60
March 23, 2005 at 9:55 am #129740iadom
ModeratorPenguin45 wrote:Without the model number and serial number we’re guessing here chaps.
I checked on the earlier thread from this poster to ascertain which type of appliance was involved .
March 23, 2005 at 10:05 am #129741admin
When the heat was working when i changed the stats i run it on a cooler cycle and it was not hot like you suggest and the drying light was on. im at a loss really!, to call hotpoint out its gonna be half the price of a new one dont know what to do i feel i like to have a go myself as you dont know who best to ring to look at it there is so many rip off merchants..
March 23, 2005 at 10:40 am #129742iadom
How old is the dryer, if it is under 5 years old I would strongly recommend that you contact Hotpoint. The dryer neon should be off whenever the motor reverses, it should not be on all the time.
March 23, 2005 at 11:23 am #129743admin
The dryer is 4 years old, is there anyone you would recommend instead i live in west mids area or do you think hotpoint is the best bet.(Thanks for your quick responses)
March 23, 2005 at 11:41 am #129744Dave_Conway
ParticipantRe: changed thermostats
1st part of your postcode please ?
Have you checked the directories and repairs@ ?
March 23, 2005 at 2:50 pm #129745iadom
net 0519 wrote:The dryer is 4 years old, is there anyone you would recommend instead i live in west mids area or do you think hotpoint is the best bet.(Thanks for your quick responses)
If as I suspect the heater control relay which is mounted on the Dryness module has stuck then the cost of this module together with another set of stats will cost you just short of £100. The possibility of sourcing a second hand module or a recon are very remote due to the age of the machine and the very rare failure of this module. There is a very slim chance that the rotary control unit is at fault, this is around £25 but my money would definately be on the module.
March 23, 2005 at 3:03 pm #129746Martin
iadom wrote: The dryer neon should be off whenever the motor reverses, it should not be on all the time.
I wonder if net 0159 has made this observation?
