Fault on this is its completely dead, no lights on regardless of programme.
Power seems to stop at the module, so i’ve replaced this. Now the active light & water empty light comes on but nothing else works!
I’ve checked the start button, float switch, door switch and wiring.
Has anyone else any ideas? or is it a faulty module?
Check the water tank hasnt lost the connector, ive had a few that the water connector tank / float chamber has pinged off and the spiggot dissapeared. That certainly would give you the water lamp problem. 💡
