Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint TDC60P Drying Light
- This topic has 10 replies, 3 voices, and was last updated 13 years, 2 months ago by
Neil88.
January 26, 2013 at 2:35 pm #73767
Neil88
ParticipantAdvice needed please – tumble dryer (hotpoint tdc60p) not heating – when switch on drying light flashes for a second and then stays off – just cold air. any thoughts?
January 26, 2013 at 4:39 pm #388724iadom
ModeratorRe: Hotpoint TDC60P Drying Light
Thermostats, heater, bad connections, faulty dryness module. Sadly the fault description points to the £100 dryness module. 🙁
January 26, 2013 at 6:54 pm #388725madangler1
ParticipantRe: Hotpoint TDC60P Drying Light
Check the stats first then the heater the. Go from there
January 26, 2013 at 7:18 pm #388726Neil88
Thanks – have just replaced heater and thermostats so guess must be dryness module. It that easy to replace?
January 26, 2013 at 8:19 pm #388727iadom
At £100 for the part after wasting money on parts you should have tested first I should say not that difficult to fit but possibly more than the machine is worth. 🙁
January 26, 2013 at 8:54 pm #388728Neil88
Fair point. Are there any checks/tests I can do to confirm that it is the dryer module?
January 26, 2013 at 9:13 pm #388729iadom
There is another thermostat, hidden inside the top of the door opening, testing that might be a good idea.
This type of fault on the dryness module can usually be seen in the from of burnt connections on the module. No tests as such.
January 26, 2013 at 10:16 pm #388730Neil88
Thanks – on another forum someone has suggested the orange relay switch (Schrack RT314024) on the circuit board of the dryness module (blue colour) is faulty. RS electrics and Farnell has it. Costs £2.50. This seems worth a try – any thoughts?
January 26, 2013 at 10:32 pm #388731iadom
As far as I am aware I have heard no reports of successful repairs of this pcb. One of the major players in pcb repairs EMW will not repair this pcb due to corruption of other components when the relay fails, you may not even have a faulty relay, just burnt contacts.
Have you checked the door mounted stat?
January 26, 2013 at 10:53 pm #388732Neil88
Yes – that’s fine. I guess it’s the dryness module then – assume this is the one http://www.espares.co.uk/part/tumble-dr … -modu.html. If it doesn’t solve the problem can just return it….
January 26, 2013 at 11:11 pm #388733iadom
Be very careful, I have had a quick read of their T&C’s, can see no mention of pcb’s but I would get confirmation in writing first as very few if any parts suppliers will accept electronic circuit boards back for credit. If I buy a pcb from any of the major suppliers to the trade there is no warranty or returns on pcb’s full stop.
Sent from my iPad using Tapatalk HD -
