HOTPOINT TDC60P STATS
  • #41503
    mbdas
    HI 🙂
    I’ve put 3 lots of rear stat kits in this and it works for about 3 loads and blows the cutout stat 👿 the capacitor is ok, condensor and filters and front of the door are spotless . customer has been drilled to set and forget the dryer 😈 is this a module fault or the sensor in the drum ❓ Any help at this point would be great 🙂
    Thanks Mark
    #270410
    Re: HOTPOINT TDC60P STATS
    Often caused by dryness module fault.
    Is the heater light on as soon as you select a programme before you press start button, or does it stay on during short reverse tumble. If it does the relay on module has stuck.
    mbdas
    Thanks 🙂
    didn’t notice ,I will stick another set in and check it again . 🙂
    Mark
    #270412
    grazzamongrel
    reverse timer?
    #270413
    grazzamongrel wrote:reverse timer?
    This model doesn’t have one fitted grazz. It’s ‘dryness module’ does all the work and causes all the probs mate. 😉
