Re: Hotpoint TDC62
Switch the selector knob on, if the heat light is lit before you press the start button then the module is faulty, or set it on and wait untli it does the short reverse (anti clockwise) tumble. If the light does not go out then its the module.
The module is quite expensive and sadly EMW/QER do not repair these. Not heard of anyone who has successfully replaced a heater relay on one of these boards yet either. According to Tony at EMW the processor is usually corrupted when the relay fails. 😥
