Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint TDC62
- This topic has 6 replies, 3 voices, and was last updated 11 years ago by
joe57.
March 21, 2015 at 5:35 pm #84468
joe57
Participantdrier works ok except drying light is on constantly and dryer doesnt cool down at end of cycle — any ideas
March 21, 2015 at 5:48 pm #425715iadom
ModeratorMarch 21, 2015 at 9:11 pm #425716nobeone
ParticipantRe: Hotpoint TDC62
What are the chances? My TDC62 has just started to have the drying led on all the time and is heating even on the airing setting. Thanks to the above post i have checked the relay and it is short circuit as predicted. CPC do an exact replacement for £2 so it is in the post … Great work people!
March 25, 2015 at 1:33 pm #425717nobeone
So for me at least, the saga continues, I have replaced the relay and now the drying LED behaves as expected but now no heat … I will start a separate post rather than hi-jack this one!
March 25, 2015 at 1:42 pm #425718nobeone
Thread for my continuing problems tumble-dryer-forum/hotpoint-tdc62-heat-t86755.html
March 25, 2015 at 5:04 pm #425719joe57
Now this is a strange one – whilst waiting for the new relay , i needed to use the dryer but was going to keep a careful eye on it because of the problem — turned the selector switch and NO DRYING LIGHT – pressed the power button – light came on and dryer went through cotton cycle with no problem [ even cooled down ] the exactly the same on synthetics cycle .Then to cap it all off the relay arrived in the post [ will save that for when the fault reappears properly [ as it possibly will ] Big Thanks for assistance
March 26, 2015 at 5:02 pm #425720nobeone
It is not at all unknown for relays to stick rather than weld contacts and for them to become unstuck over time and/or after a calibrated tap etc. I would expect the fault to reappear at some point … as it happens when I took my relay out to test it originally it was stuck, I put it back while I awaited the replacement, when I swap the new relay in I compared coil resistance and contact resistance with the old one (‘cos I am like that) and, what the, the old stuck relay had become unstuck. Seems yours has done the same. I put the new relay in regardless …
