hotpoint TDC62G killing toc’s…
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint TDC62G killing toc’s…
Viewing 15 posts - 1 through 15 (of 17 total)
  • #21405
    whiskeyjack6058
    I have come accross a Hotpoint TDC62G condensing sensor tumble dryer which is popping the one shot 106o toc (kit number 1701583 green spot). I have checked all the usual, the condensor unit is perfectly clear and air flow is fine and so is the filter. The TOC inside the door also is working ok. I am unable to test this machine to see if the cool down is working as it’s a sensor dryer which leads me to think the pcb may have failed causing the machine to not cool down before the end of cycle perhaps. The PCB is expencive so Im lothed to order it incase its not the real fault. Also the connection for the brush wich works on the sensing system is all in perfect working order with no bad connections. Anybody any ideas?
    Thank you.
    Robert.
    #190709
    Re: hotpoint TDC62G killing toc’s…
    whiskeyjack6058 wrote:which is popping the one shot 106o toc (kit number 1701583 green spot).
    May I just correct you one that one? The Green spot ‘one shot’ TOC is in fact 130 degrees 😉
    whiskeyjack6058 wrote: Anybody any ideas?
    OK fine on everything you have checked…very good! But what exactly are the symptoms the user is finding with this (apart from it suddenly not heating of course). And if you were able to put in a load of damp washing, does the machine reverse tumble OK?
    By the way, you could always fit a Qualtex (TOC26) auto-reset 130 degree TOC in it just for testing purposes you understand? 🙂
    Just a footnote thought?….Are you fitting the stats the right way around I wonder?…Green spot to the left don’t forget otherwise the one shot will not perform the same as a 106 degree stat and will surely blow pretty quickly. 😉
    #190710
    PCB failure can cause constant stat failure. You will normally see the heater neon illuminated as soon as you select a programme, before you start the machine if this is the case.
    I do not understand why EMW or QER will not repair these modules, I am sure it is only a sticking heater relay.
    SDR
    make sure customer is not taking load out before cycle finished, this also kills stats as no cool down period is alowed.. obvious i know but these women all do it :rolls:
    #190712
    roy1
    1. Customer overloading the drum gives
    reduced air flow blowing cut out
    2. Remove the condenser and check the cooling fan looks clean, dog hair blockage ?
    3. Replace front drum stat, if this fails to cycle
    the heater cycles on heater stat
    Roy
    #190713
    bubs
    had one recall due to a faulty motor cap.
    Graeme
    #190714
    whiskeyjack6058
    I Think my origonal thoughts of a faulty PCB could be behind this one. I have it sat in my workshop under-going lots of tests with damp washing. I drilled a hole in the back of the stat so I can keep re-setting it. The drying neon is on before the start button is pressed as Iadom mentioned. This inspired me to give the relay switches a quick tap with a screwdriver handle and the drying light is now out, but it has now developed a no motor action fault… Ehhhhh things we do for money…. Thanks for your help guys. Customer thinking about goiong back to Hotpoint under 5year parts warrenty.
    #190715
    Your initial description pointed towards PCB, I have changed a few for exactly this fault, after eliminating all of the helpful suggestions above.
    Simon46
    Yes i have had similar but never got a go ahead on repair. one cycle and stats blown.
    S.
    #190717
    phil59
    hi can anyone give me some info on emw i use qer but have not heard of emw thanks phil
    #190718
    johnmac11
    try this,
    http://emwelec.co.uk/
    John
    #190719
    phil59
    cheers john great help phil
    #190720
    flash
    HI im having same problem with a creda tcr2 on the first visit I thought good one a nice easy job so i thought , but how wrong i was changed the one shot a quick test and away i was next day the costomer phoned no heat went back fitted anew element compleat with stats but it keeps blowing the toc so i was wondering before i go back as it will my forth visit and i am starting to look daft can anybody tell me is it the pcb or timmer
    #190721
    maltheviking
    Hi Jim
    I am sure that I have had QER repair one of these boards in the past, if it is the board that I am thinking about, then the fault was a faulty transformer on it 😉
    Mal
    #190722
    I have had at least three, all with exactly the same sticking relay fault, phoned both and they didn’t want to tackle them.
