Hotpoint TDC62P Condensor Dryer -no heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint TDC62P Condensor Dryer -no heat
  • #75545
    Latham63
    Checked heater + stats ok. Is there a heat sensor above door on these? Also there is a pcb which controls the sensor drying I beleive? Are my assumptions correct?
    #395264
    Re: Hotpoint TDC62P Condensor Dryer -no heat
    There is a stat in the top of the door surround. Pcb failure quite common on these, the dryness module is very expensive but if you look at the ‘Simple PCB Repairs’ thread you will find a link to another thread from a member of the public who managed to repair his pcb.
    Link HERE
    #395265
    Did one a couple of weeks ago. It was the RT314024. I think the MOTP was probably just taking the sledge approach, although I haven’t read his post. Not sure, but I imagine the other relays may be controlling the motor.
    Mike.
