Hotpoint TDC62P not heating
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint TDC62P not heating
  • #56718
    massey
    Can anyone help havea Hotpoint TDC62P condenser dryer which seems to be functioning fine, all apart from it not heating! I have changed the two thermostats at the rear and the heater element, but still no joy. All lights on the front are normal.
    #328570
    Re: Hotpoint TDC62P not heating
    There is another thermostat located in the top of the door surround, a bit fiddly to get at.
    If that is OK and all of the wiring connections check out then the (very expensive ) dryness module may be at fault.
    Theoretically it could be the selector switch but I have never had to change one of those.
    #328571
    dachwilson
    I also have a TDC62
    I have tried several times to get at this thermostat’s fixings but without success.
    Can anyone suggest a way to access it for testing?
    #328572
    It usually helps to snip off the plastic cable tie from around the wiring harness just above the stat from inside the top, ( with the plug removed of course) .
    Then by removing the two screws it is just possible to pull it down far enough to test or replace.
