Hi gents
tdc62p select auto dry heater comes on & work ok for a few minutes then the heater switches off and will not come back on suspect module fault can any one comfirm this
cheers alro
Have you checked there is continuity from the sensor band through the sensor brush etc if there is an open circuit there, it will mimmick a dry load even when load is wet and end dry, other than that i’d go for dryness module. jj.
