hotpoint tdl 10
  • #8271
    milo
    hi, noise problem with my tumble tryer.
    it appears that the front end of the drum is loose and rubbing against the front support chassis. i found what looks like a “belt” brokken. i think this may be a “guide” for the front end of the drum.
    could you comment!
    regards
    milo
    #127766
    Re: hotpoint tdl 10
    Milo,
    Yes it will be the front drum support and drum bearers that have worn away. The part you found looking like a belt is in fact the felt seal. It is likely your machine will need a replaced Drum Front Air Duct assembly that incorporates the relevant parts as a unit.
    Could be a costly repair though, to be sure, give me the first 2 digits of your machines serial number?
    milo
    Re: hotpoint tdl 10
    hi,
    serial no 90100199.
    regards
    milo
    ps thanks 4 quick reply.
    #127768
    Re: hotpoint tdl 10
    Milo,
    Probably not good news then 😥
    I reckon it needs close inspection (dismantling) to be sure. At the very least you will need 3 of 1701674 Bearing Pads & a 1701676 Felt seal. But usually when they get in the state you discribe then the front metal plate wears too badly in order to replace these bits. 🙁
    As a consequence you will need a new Front Drum & Duct Kit (Part No 1702495) to fix it but sadly that part is expensive and in my opinion uneconomical to consider 🙄
