Hotpoint TDL11P
  • #50310
    jackster
    Hi all,
    I have got a call to this machine on Monday, basically the customer has purchased a new belt but calnt fit and called me for help.
    Never done one of these myself, any tips??
    Thanks in advance,
    Chay
    #304356
    garn
    Re: Hotpoint TDL11P
    HI BUTTY CANT FIND THE HPT PART NUMBER HEARS ONE FROM CONNECT
    Belt fitting/removal tool (5031689741125)
    #304357
    jackster
    Re: Hotpoint TDL11P
    Is there any chance of doing it without one, the job is booked in for Monday 😯
    I will deffinately order one anyway though,it will come in handy.
    #304358
    garn
    Re: Hotpoint TDL11P
    Can be A Fiddle Sometimes you can Either get it on Strait Away or end up in A bit Of A sweat.
    You Will have to From The side panel Or you may Have To remove The Plastic 4″ vent pipe or Some People try And Force it On
    by way of putting it On The motor Shaft And Round The Drum And Lifting The back Panel On . But A That’s Really Bad Move And bad Practice
    if Your A handy Guy you Could Knock one Up In About An Hour
    all You Need is A bit of Conduit Pipe A Washer That Slides Over The Pipe A hacksaw And A Welder
    i Could Send you The Schematics If You Like save You A few bob To
    Garn
    #304359
    bazza500
    Re: Hotpoint TDL11P
    If you type “Hotpoint AND belt AND fitting” into the search box there is loads of discussion on this.
    #304360
    A1_Domestics
    Re: Hotpoint TDL11P
    Give me a call later. I’ll explain how I do it with 3 screwdrivers. Piece of p*ss.
    I’ve left my number with your daughter/wife I think.
    #304361
    jackster
    Re: Hotpoint TDL11P
    Cheers mate!
    Ill give you a ring,
    Chay
    #304362
    Re: Hotpoint TDL11P
    Or girlfriend 😉 😀
    #304363
    bazza500
    Re: Hotpoint TDL11P
    or Mistress 😀
    #304364
    garn
    Re: Hotpoint TDL11P
    All Done Butty
    Check Your Email
    1x belt tool And A Drum locking tool Saves Bending Saves Your Fingers From That Sharp Alloy also removes The Inner bearing Race.
    Garn Solutions 😉
    #304365
    jackster
    Re: Hotpoint TDL11P
    iadom wrote:
    Or girlfriend 😉 😀
    14 year old daughter as it happens 😀
    #304366
    gandh1
    Re: Hotpoint TDL11P
    couldnt get on with hpt belt tool.
    so i modified it. with an old bike seat post tube. now much more leverage. maybe i should have modified myself tho and grown some muscles?!?
    ps jackster check ur front bearing, if its has the metal lip & felt support worn down to next to nothing, and has caused the drum to jam and therefore belt to snap, its a lot of hassle to sort out
    see here—>http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=48175
    good news is still my labour intesive slight-bodge (original parts no longer supplied) repair seems to be working fine (touch wood) but i spent 2 hours in the work shop polishing the scrapes out of the inside of the drum with w&d, brillo, and polish… never again!
