Hotpoint TDL52 problem!
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint TDL52 problem!
  • #66439
    skye1974
    Hi, the spindle on my tumble dryer had worn right away so we fitted a new drum spindle with a kit purchased online. It all seemed to be a straight forward process but when we plugged it in to test it, the drum isn’t spinning freely and there’s a burning smell! Needless to say I have unplugged it and need to investigate but does anyone have any ideas what I might have done wrong when I put it back together?
    #364185
    Re: Hotpoint TDL52 problem!
    You will need to check (with the belt off the motor) that the drum is sat correctly on the front nylon support bearings. And also that the drum is not rubbing against the back panel? The burning smell either the belt burnt up or worse still the motor windings shot!
