Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint TDW SF 83b EP (UK)
- This topic has 11 replies, 4 voices, and was last updated 7 years, 11 months ago by
scots.
April 26, 2018 at 5:36 pm #93811
scots
ParticipantAnyone know what F15 error is on these tumble dryers?
I know they are basically Whirlpool but cant find any usefull details.
I have tested the usual, heater, toc, pump and the motor does run, fault comes on after a few minutes.Thanks in advance
BrianApril 26, 2018 at 9:09 pm #455598electrofix
ModeratorRe: Hotpoint TDW SF 83b EP (UK)
Should be able to find out but not at home for a few days. If nobody has checked will try to remember to look
April 27, 2018 at 7:48 am #455599scots
ParticipantRe: Hotpoint TDW SF 83b EP (UK)
Thanks Dave
April 29, 2018 at 4:13 pm #455600Hollytree_Technical
F11 to F19 is listed as:
MCU failure (only for BPM motors) or BPM motor failure (BPM motor only).
Switch off/on appliance. check wiring from ACU to motor. Apply service reset procedure.
Reset Procedure:
Safety failures can be reset after the failure in the machine is corrected by the following procedure:
Within 10 seconds the following sequence must be performed:
a) turn selector switch in 6 o’clock position (down)
b) push “start” button three times.
c) turn selector one position CW (airing program)
d) push “start” button three timesJem
April 29, 2018 at 6:23 pm #455601scots
Thanks Jem
will give it a go and let you know
Brian
April 30, 2018 at 7:03 pm #455602electrofix
have now pm’ed you manual
May 1, 2018 at 7:50 am #455603scots
Very useful Thanks Dave
May 3, 2018 at 7:25 pm #455604scots
Turns out to be the motor, really showed up on the test program
Motor from Hotpoint £232.92, Connect £199 + VAT to me.These motors look similar to what’s fitted in some Beko autos.
Not like the good old induction motor prviously fitted to dryers but now a cheep looking permament magnet style with a control board installed.New dryer = £293
I have suggested they get in touch with HotpointThanks again Jem and Dave
May 3, 2018 at 7:52 pm #455605electrofix
well there u go connect are screwing you
cost from Qualtex £143 cost maddock £160
its only £232 from Hotpoint inc vat so where are they getting £199 from
still not worth doing I agree but time to re-evaluate connect
June 6, 2018 at 5:08 pm #455606snig
Hi, sorry to jump in on the end of this but any chance you could pm me the manual as well, been struggleing to reset one since f04 fault !
June 6, 2018 at 9:46 pm #455607electrofix
sorted
June 7, 2018 at 7:57 am #455608snig
Thanks, very helpful
