Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Hotpoint tdwsf83epz
- This topic has 13 replies, 2 voices, and was last updated 2 years, 4 months ago by
ngovier.
November 12, 2023 at 9:46 am #102373
ngovier
ParticipantCan someone tell me where the humidity sensor is on this unit. Clothing is still very damp when finished I have replaced the heater block
November 12, 2023 at 10:10 am #488528electrofix
Moderatorthere are really only 2 ways to do it
you can have a damp sensor such as a metal strip. normally at the bottom of the door appature inside or the drum can be split electrically to sense moisture
or you use the temperature differences between the front and back temp sensors to calculate moisture content
I dont know which this uses due to tech info or decent photos of parts
November 12, 2023 at 10:31 am #488529ngovier
ParticipantOn spare parts they show a metal strip but where is it??? Thanks for the quick response
November 12, 2023 at 11:24 am #488530electrofix
Moderatornormally just inside the door. open door and if you held a mirror inside the drum you could see it
do you use tumble dryer sheets because these can coat sensor giving false reading. if not give it a good claen and see how things go from there
some dryers allow you to alter level of dryness, dont know with this model without looking in owners manual
November 12, 2023 at 12:51 pm #488531ngovier
ParticipantI tried to get a service manual but no luck I looked as you said but still cannot see it
November 12, 2023 at 3:16 pm #488532electrofix
Moderatori could not see metal srtip on spares what site you lookin at ?
November 12, 2023 at 7:19 pm #488533ngovier
ParticipantThankyou I have found it I was looking where the fluff filter is. When I put my head in the drum I saw it. Cleaned it with alcohol and now trying it.
November 12, 2023 at 8:03 pm #488534electrofix
Moderatorthats the front NTC temperature sensor
detects heat not moisture. it can be use to detect moisture by measuring temperature differences between the front and rear temp sensors
November 23, 2023 at 8:35 pm #488535ngovier
ParticipantStill not convinced it’s repaired sometimes it seems to dry other times it comes out hot but not dry. Have checked and cleaned filter and washed condenser. The sensing light is always on might be a clue. Any help please
November 23, 2023 at 9:05 pm #488536electrofix
Moderatormake sure the condensor is clear both ways as cold air has to go through it the other way or it wont work. Also check cold air fan as had a lot of them full of fluff
December 5, 2023 at 5:25 pm #488537ngovier
ParticipantCondenser is clear where is the cold air fan
December 5, 2023 at 9:56 pm #488538electrofix
Moderatorcold fan right hand side front
did you check condensor both ways
front to back and left to right both must be clear
December 10, 2023 at 8:34 am #488539ngovier
ParticipantYes, cleaned it completely, trying to look for the fan now.
December 11, 2023 at 4:32 pm #488540ngovier
ParticipantFound the fan there is a black shroud the front and to the back how do I remove them to see inside to see if they want cleaning,the one at the front has a sensor init
