hotpoint timer
  • #64538
    abbots
    hi,
    9516 hpt.
    the original 904/2199/06 timer has gone can i fit a 904/2199/05 as a replacement?
    any info. much appreciated.
    cheers.
    john
    #357327
    Re: hotpoint timer
    as far as i know yes but its such a rare event these timers fail what wrong with it ?
    abbots
    Re: hotpoint timer
    the neutral terminal burned out, seen loads of them but run out of ’06’ timers.
    cheers.
    jk
    #357329
    Re: hotpoint timer
    you can normally fix them by taking apart done loads never scrapped one for that
    or what i should say is cant remember scrapping one as these are old machines now
    abbots
    Re: hotpoint timer
    cheers
    #357331
    Re: hotpoint timer
    remove motor from rear
    remove circlip from top rod then slide out both rods
    unclip switch section
    gently prise off front switch section one of the contacts will stay attached to main body
    if contact has melted housing and moved upwards do not remove or try to reposition
    clean contacts and the one that has burnt, remove the switching strip and bend it slightly to help it make connection with both contacts ( because its melted the case and moved contact)
    cafefully bring the units back together you will have to carefully push the contact that remained on the main body under the switching bar
    put both timer halves back together and put rods in
    test with a multimeter to see if you continuity. be aware one of the contacts wont work with timer knob in off position. waggle timer knob shaft to make sure contact wont disconnect. if it does strip down again and bend contact a bit more and repeat
    when reinstalling timer clean all brass connection and use 4 new spade connectors and discard green block
    hope this may help
    abbots
    Re: hotpoint timer
    cheers .
    jk
    #357333
    Re: hotpoint timer
    Phew! That’s pretty skilfull sounding. Hats off to Dave. I often used to just bridge the neutral as the switching was still working on the live side and if it was gone on the live side and OK on neutral, I would swap them round. Not ideal I know, but the chances of a problem arising would be pretty remote. Even that method was a tad fiddly though because you have to bridge two neutral wires to one or something, I don’t remember exactly. Think EMW might still do some re-cons.
    Mike.
