Hotpoint timer diagram
  • #72542
    paulun
    Hi pulled wires off hotpoint tumble dryer timer one by one but still think Iv made a mistake need a timer wiring diagram for a CTDOOG DATE CODE 95 Thanks.
    #384833
    Re: Hotpoint timer diagram
    you should be able to check it with an ohm meter
    you know that the heater and motor are in circuit but the heater turn off 5-10 mins from end
    so with side off set timer at 5 mins measure resistance and disconnect motor to check reading dissapears ( you will still have a higher reading due to the timer motor
    then turn timer to where element is in and reading should go down
    watching meter if you turn timer down you should see heater disconnet first then motor
    the only thing you could get wrong then is the reverse contacts
    hope this may help
    dave
