hotpoint timers
  • #9209
    waters
    Hi.
    Does someone know the difference between timers on wm machines .
    Wm62 for instance can have 904 2425 03 or 2440 04.
    I see 04 timer fits wm 52,62,64 etc.
    So what is difference in 01 ,02 03,etc timers .
    I have 2 wn62 machines ,1000 spin.One has a 2425 03 single triac, the other has 2440 04,. 2 triacs
    #132962
    Re: hotpoint timers
    Waters,
    Best have a word with the lads at EMW for this. They are the whizz kids that will point you in the right direction 😉
    http://emwelec.co.uk/
    jimbo2207
    Re: hotpoint timers
    The replacement timer for all WM’s (digital) is 1603787. There were variations, but they were interchangeable, although the wash programs might have slight differences. The replacement motor for all of them now is Digi FHP 800/1200, part number 1604822. And yes, that means that you can soup any of them up to 1200 rpm
    #132964
    Re: hotpoint timers
    I would rather set them all at 1000rpm, the 1200s shake themselves to bits 😉
    #132965
    Re: hotpoint timers
    jimbo2207 wrote:The replacement timer for all WM’s (digital) is 1603787. There were variations, but they were interchangeable, although the wash programs might have slight differences. The replacement motor for all of them now is Digi FHP 800/1200, part number 1604822. And yes, that means that you can soup any of them up to 1200 rpm
    Is this strictly true??
    The early 410/415 digital timer, 1601603 for a WM11 for instance, have PCB’s with connections for full size spade terminals ( two white wires ) at the front top edge of the PCB as well as at the bottom front edge, also completely different connections along the bottom edge to the 1603787.
    As far as I am aware there has been no ‘conversion kit’ for these early 410/415 units.
    however I stand to be corrected. 🙂
