Anybody had probs with the timer on this model, it’s an Eaton type, all the cams/cogs are exposed, it times thro to the crease care section & refuses to switch off. It seems as though the pink section of cams/cogs don’t seem to move at the last bit. I carn’t see any marks or burrs on the cogs, & if you move it by hand it’s fine! I know it’s a timer job but as this was a re-con for a friend I wondered if there was anybody else had a similar fault. Any Ideas how much a timer is?How long should crease care go on for?
Chris..
