Hotpoint TL51P belt
  • #38047
    Not been to this yet but sounds like it’s a broken belt. Connect lists it as 1860H7 and says, “This is not to be used as a replacement for 1703666” 😕 which is the 9 rib belt of which I have adequate stocks. Does anyone have intimate knowledge of this particular model, please?
    Mike.
    #257508
    helo_75
    just fit it, itll be fine, same length, just a little stretchier
    honest, its what i fit to them
    #257509
    Re: Hotpoint TL51P belt
    Correct belt size for a TL51 is a 1894H7 you should never use it in place of a 1703666. You may be able to squeeze a 1703666 onto a TL51, personally trying to force it over the two jockey pulleys would be rather awkward. This is not a TDL which was the earlier ( 1701658 ) stretchy belt type.
    Correct belt for a TL51 is a 1700442, takes about five minutes to fit.
    Thanks guys. I’m so glad to hear there’s jockey pulleys in there. Was anticipating knackered bearings etc. Much prefer simple jobs.
    Mike.
    #257511
    Tip it upside down, remove the kickstrip and as long as your arms aren’t over developed 😉 you can ease the front panel forward and slide the new belt around the drum and over the motor & pulleys, take care not to pull to hard on the wiring and make sure the large vent tube is back in place when you close the front up, its basically a bog standard Creda design.
    wilf
    heres how I do it
    right hand side off ease the front forward use a small screwdriver to unblock the fluff from the guides thread the belt over the front and spring the pulleys to fit the belt good job!
    wilf 😉
    #257513
    Good advice guys, thanks. Turned out I had the 1894 belt in stock too. Tried Jim’s method but couldn’t get front to come away from drum. (Maybe my arms are over-developed). So reverted to Wilf’s method. Soon realised I’d done these before by laying m’c on it’s back and removing front completely. New method a bit quicker but encourages laziness. With my old method I used to give the insides a vacuum out.
    Mike.
