Hotpoint TL61 dryer parts
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Hotpoint TL61 dryer parts
  • #102167
    Help needed for my own venerable tumble dryer.
    Don’t have access to part numbers as easily these days. I need the part number for the belt. This machine has the double jockey pulleys. I also need the square, phosper bronze rear bearing, not the plastic one. If anyone has a spare one lying around that would brilliant, if not the part number or even the full rear bearing and shaft kit at a pinch.
    OK, Found belt in UKWG’s shop, also full bearing kit. In truth I only need the square bearing if any kind soul has one going spare.:)
    #487796
    bearing part no
    C00113862
    connect have got them for £9.25 plus vat and the belt should be 1894mm H7 and they are £5.04 plus vat
    you can get the non gen ones online for about £3
    will see what i have in the morning
    Hi Dave, I must have thrown several of those bearings away when I retired. Do Connect supply to general public. Would probably get a gen belt, non gen never seem to last as long. Thanks for having a look​​​​​​.
    Back again, just bought 2 rear bearings from EBay for £7.20. Just the belt to sort now, this dryer although not the best economy rating is a bit like Triggers broom.:) Over the years it has had several belts and jockey pulleys, front bearings and even a motor. This is the first time the rear bearing will have been changed. Fits in the confines of our small boiler room and vents through the wall. It will be a very sad day when I am unable to keep it going.
    #487799
    Frightening really, just checking a few belt prices and spotted one on Spares for Siemens at an attractive price of 41.99.:eek:
    #487800
    can get you into connect if you need to
    electrofix wrote: can get you into connect if you need to
    Will bear that in mind for the future but 2 bearings for £7.20 inclusive trumps £9.25 plus vat for one don’t you think.;):)
    connect is always expensive anyway same part in Qualtex is £7.13 plus vat for gen part
    plenty of belts on ebay too
    gen part should be
    C00112736
