Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint Top Loader 15690
- This topic has 13 replies, 6 voices, and was last updated 13 years, 7 months ago by
DrDill.
August 16, 2012 at 10:53 am #70981
DrDill
ParticipantHi All,
its been at least 12 years since i last rebuilt one of these top loaders, i am going to see one on saturday and customer is complaining that it starts to wash then stops, spins and drains okay. I was thinking possibly capacitor or relay start device? any one have any ideas?Nigel
August 16, 2012 at 11:06 am #379523Martin
ParticipantRe: Hotpoint Top Loader 15690
Heater open circuit?
August 16, 2012 at 4:05 pm #379524HotDog
martin is correct but more likly wire burnt off heater terminal or if not check stat control switch connection they also were prone to burning
August 16, 2012 at 7:24 pm #379525maltheviking
If you manage to get it going dont forget to tell the customer that the T/L’s have been obsolite for a few years now and you cant gtee. your repair, no parts available other than the odd copy bit.
August 16, 2012 at 8:37 pm #379526DrDill
A few fault reminders there chaps, memory has been jogged!
Many thanks to all of you, I will let u know the outcomeAugust 16, 2012 at 10:36 pm #379527iadom
ModeratorRe: Hotpoint Top Loader 15690
The rocker switches for the water levels sometimes burn out, heater load is through these.
I may still have a hard copy manual for this machine, no doubt Cliff, aka Hotdog will have one as well.
August 18, 2012 at 9:28 am #379528DrDill
Well it was none of the above, gearbox was siezed, turns out it had sat in their holiday home for over a year unused, i freed off the gearbox by manually turning the power unit pulley, fired it up and it squeked and groaned for about 5 minutes then returned to normal sound, inside was like new, customer was very happy, and so was i!
August 18, 2012 at 9:53 am #379529maltheviking
Seized? Give it a few months and there will be a pool of oil on the floor!
August 18, 2012 at 1:05 pm #379530iadom
Its very unlikely that the gears themselves have siezed, more than likely the long, gyrator drive shaft will have become tight inside its sleeve.
August 18, 2012 at 7:51 pm #379531DrDill
You don’t have to guess the fault now, I have told you what it was.
August 18, 2012 at 8:19 pm #379532iadom
DrDill wrote:You don’t have to guess the fault now, I have told you what it was.
Whos guessing the fault now?
I am just using 42 years of experience, over 12 of them as a Hotpoint engineer to tell anyone interested what the most likely cause of the gearbox siezing was. 😛
You did say in your first post that your customer said ‘it started to wash and then stopped’ which is why three ex Hoptoint engineers replied to you regarding the heater, as the gearbox was siezed then it could not have washed in the first place. 😉
Jim. Ex Hotpoint Senior Engineer.
August 18, 2012 at 9:47 pm #379533DrDill
You can have 1000 years experience, the fault was the gearbox siezed! I was grateful for the initial reminders of what to look for, it didn’t matter in this case as the gearbox being siezed was the fault.
Oh and by the way I have repaired 100’s of them, one of my favorite jobs replacing the power units.August 19, 2012 at 8:08 am #379534iadom
Good morning Dr Dill, I’m sorry if you have misunderstood my last but one post. I was not as you say ‘trying to guess’. As you have already stated that the fault was caused by a seized gearbox.
I was merely postulating on the most likely cause of a seized gearbox which is the long drive shaft seizing up inside its outer tube. As this has virtually no lubrication apart from the toothed end which is inside the gearbox it will almost certainly seize up again if it is left for even a few weeks if it doesn’t get anything to help it stay free.
Like you I have fitted many hundreds of complete power units and also complete gearboxes but in what may be seen as ‘the good old days’ of the late 60’s early 70’s every single component of these units was available as a spare part, even down to the cork gasket. Over the years I have stripped gearboxes to replace gear quadrants with teeth missing, oils seals, broken bendix drive springs etc. However the one part I changed more than any other was the long gyrator drive shaft. When it became NLA I still used to strip them out, file off the corrosion, lubricate and refit.
I used to change the bendix spring by propping the whole machine up at each corner on a couple of housebricks or whatever was available at the time. With the floor covered in newspaper it was then possible to drop the bottom of the gearbox casing off without even removing the cabinet, inner or outer drum. When the bendix spring failed you got the classic wash on spin action .I had one old dear with a top loader who used to jet off to Benidorm for three months every winter. I used to get a call early March to go along as the machine had seized up. It was back panel off, remove pump drive, allow a few inches of water in to cover heater then blow up pressure hose to close switch. Remove drive tripod and top hat seal, grip the top of shaft with mole grips whilst injecting WD40 down the side of the shaft. When I had released it I then allowed it to wash whilst pouring more WD40 on it. I did this for four or five years but sadly on the last occasion it would not budge, to make matters worse she had been told that she was not well enough to fly anymore. 🙁
You are certainly correct about repairing these machines, far more rewarding and satisfying than the current, sealed drum rubbish to be sure. 8)
August 19, 2012 at 8:48 pm #379535burns
Thanks Jim. Really enjoyed the trip down memory lane. Although my time at Hotpoint it was new power units / gearbox, clutch, pump or motor. With the odd thermistors. But I did find changing the power units very rewarding jobs. Unless I got two together….
