you need to check the drain hole behind the pump isnt blocked
if you take the pump unit out, youll find a small drain hole at the bottom left of the grey plastic housing…. i push an old broken tumble dryer belt through and pull it out through the condenser housing to make sure the restriction doesnt flow back through
if it doesnt drain properly, it fills up in the fan chamber, then sprays water over the heater
