Hotpoint Tumble Dryer back bearing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Tumble Dryer back bearing
  • #102409
    washingmachinewoman
    Would appreciate your opinion on whether to replace the pin or reuse the old one when changing the tear drop back bearing on hotpoint tumble dryers.
    At the moment, I am getting the repair kits as they are cheaper than buying the separate parts. I usually only use the bearing and the pin out of the kit, leaving me with lots of extra parts, which seems wasteful.
    The tear drop bearing is cheap enough, but the pin I can’t find for less than a tenner which is a complete p***-take, some even sell it for over £20!!
    I’ve always assumed that once you straighten the pin, it will loose its integrity, so is a part that should be never be refitted.
    What do you think?
    Lucie
    #488694
    refitted lots of pins with no problem but would only do it once
    cant believe Hotpoint want £16 for a bit of bent wire
    you could probably find a nail the correct size you could buy a handfull for less than that
    washingmachinewoman
    electrofix wrote:refitted lots of pins with no problem but would only do it once
    I know, right!
    #488696
    washingmachinewoman
    Had a look on eBay and can find split pins correct size for the job in marine grade stainless steel for about £4 for 10, even cheaper for regular stainless steel. Should be easier to fit too!
