Hotpoint Tumble Dryer CTD40P
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint Tumble Dryer CTD40P
  • #87337
    Rai
    Hi There, I have got a problem with my Tumble dryer, any advice help will be appreciated.
    I had replaced Heater elements that came with its Thermostat and thermal cut out.
    When switching the dryer the drying indicator lights comes on the machine begins to spin after about 30 seconds it pauses and then starts again but this time the Cooltumble light come on along with the drying light on.
    It seems as if the Element hasn’t switched on at all when touching the back panel it is all cool. Any suggestion will be appreciated. Thanks and regards.
    Rai
    #434538
    Re: Hotpoint Tumble Dryer CTD40P
    Either incorrectly wired or wrong heater fitted or the pcb is faulty or has been damaged.
    Have you contacted Hotpoint about the safety/fire risk recall on this appliance?
    NB. There are four different heaters for this model as well and it has a safety stat, a cycling stat AND an ntc fitted.
    If you can give us the full serial number and the commercial code from inside the door and the part number of the heater you have fitted we can tell if you have the correct one.
    #434539
    Rai
    Hi Thank you for your prompt reply, the wiring configuration on the new heaters were exactly the same color coded and positioned. It has got the 3 items fixed on the Heater mounting bracket which I assume are 2 stats and a thermal cut out units.
    The Replacement heaters were purchased from E Bay. The sellers advert says replaces C00258828, it looks exactly the same to the one removed. Photo of the new heaters attached. The older Stats and cut out are all black in colour the new one has got 2 black coloured and 1 white.
    Thanks for informing me about Fire safety, after seeing your response I had submitted the online report to hotpoint.
    The Model NO is CTD 40P Serial NO 601240071.
    Will very much appreciate for your feedback on this matter.
    Thanks and Kind regards. Rai
    #434540
    On my iPad ATM , will give you the correct part number later when I have checked on my main PC but I can tell you that is the wrong part. The white and black components you refer to are the ntc’s. They are not interchangeable .
    EDIT: The correct part number is C00258799.
    #434541
    Rai
    Hi iadom, Thank you very, very much for your assistance, in the meantime I will arrange to return the Heaters that I have purchased from E Bay as they had mentioned this heaters are for CTD40P. I will source from other suppliers. If you may have any information on who could supply the correct type then please let me know accordingly.
    Thanking you for all the advice and assistance rendered over this matter.
    Rai
    #434542
    Rai wrote: If you may have any information on who could supply the correct type then please let me know accordingly.
    That is the correct element for a CTD40, just not your CTD40.
    for suppliers look no further than HERE 😉
    #434543
    Rai
    Thank you very much for all your assistance I will order it from the supplier you have suggested, they seem to be having the type required. Once again thanks and regards.
    Rai.
    #434544
    Rai
    Hi Iodam. I ordered the correct Element from the supplier you suggested.I have fitted the same on the dryer and Its working fine. Thank you very much for your Kind advice and assistance. Regards. Rai
    #434545
    :tup:
