Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint tumble dryer design fault
- This topic has 12 replies, 7 voices, and was last updated 20 years, 5 months ago by
johno1998.
November 3, 2005 at 8:24 am #13008
johno1998
Participantwe are haveing problems with a hotpoint tumble dryer model zdt000 it is only 12 months old and the drum has dropped, and is now rubbing on the motor .The drum has pulled away from the front of the machine checked the dry bearing that is fine . The customer said the first one she bought exactly the same model developed the same fault.Hotpoint engineer said he could not repair and replaced it for a new one.Has any one got any ideas ❓
November 3, 2005 at 8:41 am #152621Martin
ParticipantRe: hotpoint tumble dryer design fault
Johno,
You have already asked this same question (yesterday) and it has been answered my friend. Do please try to contain one question to one thread, thanks 😉
…and in the appropriated forum is best! 😀
November 3, 2005 at 5:25 pm #152622johno1998
the model number is VTDOO
November 3, 2005 at 6:02 pm #152623Dave_Conway
I’m not sure if there is a design fault to be honest, it looks much like any other Creda made dryer, but the front is slightly different.
What’s actually happened, has the front drum support been cut through ?
Part number for the front support complete is 1702760 at £14.60 ex VAT list if it helps.
November 3, 2005 at 6:14 pm #152624johno1998
The drum has dropped, it is like the belt is to tight and is pulling it away from the front of the machine.The drum would normally sit on the dry bearing at the front of the machine, and there are what look like locating slots 3 all together that the drum rotates round on. And inside these slots are 3 plastic spacers they look a little worn but not anything major.
November 3, 2005 at 6:23 pm #152625Dave_Conway
It’s a streeetch on belt alright, it should be 9PHE1860.
You could be right in that case, poor quality cabinet and it flexes too much allowing the drum to “fall off” the front support 😕
Perhaps one of the Merloni engineers that frequent here could enlighten us ?
And this 😉
http://www.ukwhitegoods.co.uk/modules.p … pic&t=8311
November 3, 2005 at 9:45 pm #152626Flyman
Drum shaft kit required.
Includes:-
1 new extended rear bearing shaft.
1 or 2 spacer washers.
1 new rear bearing.
4 new front bearing pads.
1 new front felt strip.
1 new rear sponge/felt seal (extra thick).
1 new shaft pin.Fit the lot and it will push the complete drum forward about half an inch. Stops the drum falling off the front support and stops the drum from fouling the back panel. Can also be fitted on the condensor dryers to remove the front wheels which sound horrendous. 😕
1703080. not sure on price but around £15 to £20
November 3, 2005 at 9:48 pm #152627Simon46
Have had Indesit IS60V with motor melted belt still under warranty. Cust son had taken it apart. Perhaps the same had happened to this?
S.
November 3, 2005 at 9:54 pm #152628Dave_Conway
Flyman wrote:1703080. not sure on price but around £15 to £20
Not even that much, on Partfinder it’s about £8 ex VAT 😀
Thanks for the info Flyman :tup:
November 4, 2005 at 2:38 pm #152629aeronaut
The early ones had a disastrous failure rate for the drum fault but I was told from a good source that the newer production was OK. Maybe not…
I fear another example of Indesit ‘quality’….
November 4, 2005 at 8:03 pm #152630MickGeorge
ParticipantThanks for the info Flyman, had two of the same fault and been changing bearings and rear seal – even tried shiming the drum forward in one case it was so bad. It’s great to know there’s a mod kit out there.
November 4, 2005 at 10:23 pm #152631Flyman
Also a modified back plate out to stop the drum fouling the rear vents and the recessed area where the vent tube fits. It comes with the new enlarged rear seal already fitted. Lots of mods to these dryers due to noise problems. 🙄
November 7, 2005 at 8:55 am #152632johno1998
Thanks for the info flyman will order parts 😉
