Hotpoint tumble dryer f14 error
Home Forums Trade Technical & Spare Parts Forums Hotpoint tumble dryer f14 error
  • #102192
    dunston
    Hotpoint AQC9BF5E-Z1 will heat for about 5 minutes then all the lights start to flash and displays a F14 error.
    The drum continue to turns – stops heating.
    Anyone had this fault?
    #487893
    Not seen it myself. Can probably look it up but away till Monday.
    if you get no reply’s add a reminder Monday so when I log in from home I can see if I have any info
    Hollytree_Technical
    According to a service manual for a similar machine:
    F14: Rear NTC Over Heating
    Check the Cycling Thermostat is operating correctly.
    Check the Machines Filter is Clean.
    Check the machines air flow for blockages.
    Check the machines Plinth and air vents are not obstructed or blocked.
    Check the NTC and attached Circuit and Connections.
    Jem
    #487895
    dunston
    Thanks for your help but the customer hates the dryer and has bought a new one.
