Hotpoint tumble dryer heater thermostats
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint tumble dryer heater thermostats
  • #82672
    stratfordgirl
    I’ve always paid particular attention to getting the self resetting and non-resetting thermostats the right way round on Hotpoint tumble dryer heaters when replacing them. I suspect some people fitting these kits (especially DIY) don’t pay that much attention and get them the wrong way round.
    What would the consequences of getting them the wrong way round? Am I right in thinking this would compromise the fire protection of the dryer, as the non-resetting thermostat would no longer isolate the whole heater?
    #420552
    Re: Hotpoint tumble dryer heater thermostats
    The cycling stat on the fuse circuit would still cut on and off the heat as normal. So in effect there would be little or no detectable consequence of them being swapped over I would imagine.
    #420553
    stratfordgirl
    But if the cycling stat fails in the closed position and the motor stops going round, no safety cut-out and a potential fire I guess?
    #420554
    Not sure about catching fire but the clothes inside may be a tad crispy. 😉
    #420555
    timdowning
    The safety stat would still operate and open circuit the heater circuit.
    #420556
    Well what do YOU think?
    #420557
    stratfordgirl
    Fantastic iadom, the diagram confirms my fears are unfounded.
    The cycling stat cuts the live to both elements, the one shot cuts the neutral to both, so the heater is fail-safe even if the stats are inadvertently reversed.
