Hotpoint tumble dryer – keeps stopping
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint tumble dryer – keeps stopping
  • #9207
    Hotpoint Aquarius Condenser TDC30P. Ser: 92104822
    The dryer will start up normally and behave for varying periods between 5/8 minutes.
    It will then stop before end of program.
    The timer/programmer stops too.
    There are no noises, hot smells or any other symptoms.
    Its all clean and fluff free.
    No lights on the front panel.
    Position of temp switch has no effect on fault
    If I press the start switch and hold it, it will run. I don’t hold it in for more than 15 seconds on principle, as something may be turning it off for a good reason.
    Sometimes it will restart and run for maybe 2 minutes.
    Any advice or diagnoses help would be appreciated.
    Max
    #132958
    Re: Hotpoint tumble dryer – keeps stopping
    Max,
    Its Relay is at fault. To get a replacement simply click on this link:-
    http://shop.ukwhitegoods.co.uk/Tumble+D … Relay.html
    If you would like someone to replace it for you?…Click below:-
    Repairs@
    Ok, thanks. I’ll try that. I did wonder about it, as I could not feel or hear a click from it when i pressed the switch.
