Hotpoint Tumble Dryer TCL780
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Tumble Dryer TCL780
  • #72913
    Taff
    On switch on the clean filter light is on. When a program is selected and the start button is pressed the clean filter light goes out and the machine tumbles for about 2 minutes with the drying light on. Then the following lights flash, precare,postcare, high heat, delay timer and the start pause all flash together. There is no heat within the drum. The filter is clear as is the condenser cartridge. Both stats along side the heater are serviceable. The third item which I don’t know what it is gives a reading in megohms? The water collection chamber is empty indicating that the pump is working. Any ideas on this would be appreciated.
    #385943
    Re: Hotpoint Tumble Dryer TCL780
    The error codes for this machine are in the Known Error codes thread if you care to look.;)
    The ‘other’ device that you say reads in megs is the NTC.
    #385944
    repman
    megohms seems a bit on the high side ??
