Hotpoint TVEM70C vented dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint TVEM70C vented dryer
  • #79151
    Washdisher
    This is the fixed shaft one.
    Is it acceptable/feasible to drill out the rivets holding the shaft to the drum and attaching a new shaft? Also when I’ve searched for parts I can’t find the usual Hotpoint front bearing pads. Do they use something different?
    Any help much appreciated.
    #408161
    Re: Hotpoint TVEM70C vented dryer
    Never attempted it myself but have heard of people trying that fix.
    Front bearing pads are C00287118.
    #408162
    johnnyj
    Heard a couple of the indesit guys use a wood chisel to knock the shaft off only problem is some of the newer drums the shaft kit doesnt line up with the holes on the drum.
    #408163
    timdowning
    Done a few of late. Just whacked the old shaft off. Its luck if you leave any sharp edges though. I just used the parts that come with the version 4 drum kit. Pads included.
    #408164
    Washdisher
    Thanks for all the help. Doing this pm so I’ll keep you posted.
    #408165
    Washdisher
    The teardrop had worn down but the shaft was fine, so no need to replace.
    #408166
    jason1970
    I used to chisel off but now always drill, it is neater and no risk of damage to the drum. I always fit the V4 complete kit, C00113038 and charge accordingly. To be fair it is a good repair and will give the machine a new lease of life!
