hotpoint tvfs83 dryer
  • #98321
    eng14
    hi all went to this dryer this morning,both stats gone changed them and worked for some time heating, now heat gone again,thanks richard
    #471826
    would need more info to look it up as the above narrows it to 20 machines
    have the stats gone again ?
    eng14
    yes dave,richard
    #471828
    let me have all the model details so i can look it up to see if there is any probllems highlighted
    eng14
    thanks dave just got in,tvfs83cgp
    #471830
    still have to assume a few things
    1 that the model is TVFS83CGPUK there are other similar machines and you dont give me the commercial code to double check
    if above is correct then the stat kit should have been C00112196
    did this fail while you were watching ? if no could the cap be getting weak stopping it revolving ?
    eng14
    hi dave thanks no we went and 4hrs later it failed,i suspect thermistor overheating.is that possible to knock out the new stats,regards richard arg.
    #471832
    the thermistors both front and rear control the temp both leaving the heater and leaving at the front of the dryer
    so yes they can be a source of failure
    assume since its a vented dryer you have checked the vent to outside
