Hotpoint TVHM80CP 8Kg Vented Tumble Dryer – Loud Rumble Noise
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint TVHM80CP 8Kg Vented Tumble Dryer – Loud Rumble Noise
  • #100099
    mtuk100
    I have an 18 month old Hotpoint TVHM80CP 8Kg Vented Tumble Dryer which is making a loud rumbling noise when running as if a shoe was in the drum It also used to squeal although this appear to have stopped. Do you think the runners may need replacing? If so, is it worthwhile spending the money or should I just buy new? Strange as only 18 months old and not used much. Thx
    #479222
    kaibart
    Sounds like the rear bearing may have failed and caused more problems unplug machine and at the rear there is a half moon plastic cover this is secured with 2 screw take this off is where I would start
    #479223
    mtuk100
    I’ll try that and see if I can see any wear. Actually, sounds more a fast train going over rail joints
    #479224
    mtuk100 wrote:I’ll try that and see if I can see any wear. Actually, sounds more a fast train going over rail joints
    there is an idler pulley on the belt that by the motor. its more unusual for the later ones to fail but moving fast enough to cause this sort of noise
    kaibart
    Think you may be confusing this vented model with a condenser dave I can’t see a idler pulley on the drawing,sounds like rear bearing has failed and the shift is running on the back panel
    #479226
    kaibart wrote:Think you may be confusing this vented model with a condenser dave I can’t see a idler pulley on the drawing,sounds like rear bearing has failed and the shift is running on the back panel
    you guessed it lol
    but the way he described it it sounded like the sound was repeating quicker then the drum was revolving
    it does have 2 wheels at the front that hold the drum and one of those may have become contaminated
