hotpoint tvm dryer
  • #66429
    probson
    i have the above dryer which is making a loud squeeling noise when drying,driving us nuts!! any1 help please,thanks,Pete.
    #364162
    Re: hotpoint tvm dryer
    Full model number would help, at least 7 models start with TVM, different drum drive set up on some.
    #364163
    probson
    sorry, its the tvm560
    #364164
    That machine has the ultra tight, stretchy belt drive.
    It puts severe strain on the bearings, in particular the rear bearing shaft which often wears right through the phosper bronze bearing then slices itself in half by wearing against the back of the cabinet.
    You can see the rear bearing by removing the grey plastic cover at the back. If you get a large amount of black dust falling out then the rear bearing is goosed.
