Has anyone had a similar problem to this?
E15 fault and bleeps
machine is pumping out ok and outlet pipe is at the right height when set to spin at any speed turns once clockwise then once anticlockwise then stops. Pump continues to run untill fault code and bleeps start.
I have changed both control PCB’s , pressure switch and motor thought it might have been a taco coil problem has anyone got any sugestions this one is driving me crazy.
motor brushes are fine.
