Hotpoint Ultima 1400 WM76 – Error code E30
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Ultima 1400 WM76 – Error code E30
  • #29272
    i have tried using my Hotpoint and found it only filled up the prewash tray and then an E30 error came up. i have tried several times more to start the program but it will not fill with water at all now, going straight to the error code.
    i have various problems sometimes with this machine, sometimes the door gives an error, and sometimes it get stuck repeating a cycle over and over, but i can get round all those…..i could really do with knowing how to fix an E30 error though- i know an F30 error is a engine drive problem, is this also an E30? If so how can it be fixed?
    Also i have not had this machine from new…do you know how old it might be or where i can get a manual – i have tried the hotpoint service site to no avail.
    Thank you in anticipation of your help
    LJL 🙁
    #222545
    Re: Hotpoint Ultima 1400 WM76 – Error code E30
    E30 is no motor – probably the carbon brushes at that age (8-10 yearsish)
    Power off before extracting brushes.
    Regards
    Thanks very much Penguin. That sounds like it is worth a try. Do you know what part we need and how much it would cost?
    #222547
    http://shop.ukwhitegoods.co.uk/index.ph … 24_599_660
    One of the first two, depending upon which motor is fitted.
    Brilliant! Do you know how i can tell?
    #222549
    Er, the ones in the motor will look the same? The first ones are a snap fit into the sides of the motor, the FHP ones are screwed to the end frame.
    Thanks very much for your help… i will let you know if it works!
    LJL 🙂
