Hotpoint Ultima 8KG WMD942
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Ultima 8KG WMD942
  • #74952
    dnaxton
    I have an issue which my Hotpoint unit.
    It was working perfect this morning. But go to use it this afternoon and everything is working as it should apart from the machine doesn’t start after selecting a programmed cycle.
    The timer starts to count down as though things are working but sadly they are not. After a few seconds I get a bleeping sound and a scrolling message asking me to check the water supply.
    Message reads No water, Check supply.
    I have checked the supply and all is well.
    Any ideas
    #393353
    Muv
    Re: Hotpoint Ultima 8KG WMD942
    Water inlet valve probably faulty…
    Muv
    You should be able to hear a faint humming noise at the rear of machine if the valve is working correctly?
    dnaxton
    Is there any way to test this or bypass it to see if it clears the problem
    Regards
    dnaxton
    Can’t hear a humming noise.
    Would this valve stop the complete machine working, even the spin cycle 🙂
    #393357
    Muv
    Has a delay timer been set accidentally?
    dnaxton
    How would I check that
    #393359
    Muv
    Look at the display screen, at bottom left there should be a yellow bar illuminated next to the delay timer button to e left of it… If its lit then a delay time has been set…press the corresponding button until it cancels…..
    Of you can hold the on/off button in until the machine switches off..then switch back on again..
    dnaxton
    No delay timer set.
    When switching the machine on, everything lights up as it should but the start/pause button is flashing as though a programme is still running but it’s been paused.
    If I press the start/pause button the light stops flashing and the timer starts counting down but the machine does nothing.
    #393361
    Muv
    Ok, sounds as though either the inlet valve/valves are faulty.
    Before attemting any repair yourself, unplug the machine and remove plug from socket..
    This video should help..
    http://m.youtube.com/watch?feature=rela … wQe7–htAw
    Just a thought..can you open the door after pressing start buttton… Hopefully not!
    dnaxton
    Muv wrote:Ok, sounds as though either the inlet valve/valves are faulty.
    The door is not locking at all
    #393363
    madangler1
    If its fitted the the coo254298 board fitted I’d bet its blown. Quite common that as the suspension dampers go soft the motor catches the heat sink on the module and blown it.
    Would have happens at the end of the last spin most likely
    How soon after starting do you
    Get the water message? when the board blows it normally comes up very quickly, way before the machine would have filled if it was working as normal.
    With water
    #393364
    dnaxton
    madangler1 wrote:If its fitted the the coo254298 board fitted I’d bet its blown. Quite common that as the suspension dampers go soft the motor catches the heat sink on the module and blown it.
    With water
    I have just timed it.
    I selected the fastwash programme. It run for 6 mins before the water message was displayed. (At no point during that 6 mins did the door lock or the machine start to work, just the timer counting down)
    My girlfriend has just informed me that the last cycle did end a little strange with the door not opening immediately. Had to power it off/on to open it.
    Regards
    madangler1
    If its counting down with out engaging the door lock I’d almost certainly say its a module problem as it should not even begin with out locking the door,
    What are the numbers on the sticker behind the door? These will tell us the exact version of the machine.
    #393366
    dnaxton
    madangler1 wrote:If its counting down with out engaging the door lock I’d almost certainly say its a module problem as it should not even begin with out locking the door,
    Here you go
    WMD 942 G (UK)
    S/N 010227395 30694490000
