Hotpoint ultima condenser dryer help
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint ultima condenser dryer help
  • #72531
    Jojo2010
    Hi I am getting F4 and F8 codes and its not very often that the cloths actually dry, I clean the filters and empty the water after every use so not that
    Can anyone help please
    Thanks Jo
    #384800
    Re: Hotpoint ultima condenser dryer help
    Model number????
    #384801
    Jojo2010
    CTD85
    #384802
    Not good news I’m afraid, F04 & F08 both relate to components being switched on when they should not be, in this case the pump and the heater.
    Nearly always a main PCB failure. 😥
    PCB is around £60 but it does need programming.
    There are seven different eeproms, five different smart cards and three different PCB’s for this machine.
    #384803
    Jojo2010
    Is there anything else it could be as its mostly the F8 code I get, if not is it expensive to get fixed
    #384804
    As I said, the pcb is the most likely cause, the Indesit electronics in these are not the best. As it needs programming then you are looking at £75 to £80+ for parts before labour, it could be damaged connectors on the board but even that may have done some damage to the board itself.
