Hotpoint Ultima CTD85 TIMER PROBLEM
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Ultima CTD85 TIMER PROBLEM
  • #59796
    Chazzer-2459
    Hi there
    Ihave the above condensing dryer the countdown timer is stuck on 10 minutes and will not count down or allow reprograming it stays on the 10 minutes runs but does not dry ?
    #339631
    helo_75
    well, it wont if its stuck on 10 mins
    anything under 10minutes is a cool cycle, so wont dry
    interesting fault.. does it just stay on 10 mins?
    does it never count down
    they were notorious for sticking buttons… u may find one of the buttons is constantly depressed
    first thing to do is take the lid off, then the fascia, then the pcb, and refit it all properly and see how you go
    its unusual for a fault without a fault code of some sort
    #339632
    Chazzer-2459
    Re: Hotpoint Ultima CTD85 TIMER PROBLEM
    tried all the above and still no joy !
    #339633
    helo_75
    itll be one of the pcb’s
    now it gets expensive….. cos it coud literally be either
    #339634
    gandh1
    just check the the drier element, had this on a ctd80 (white version) as it stuck on 20 mins and tripped few mins afterwards. replaced pump, but still stuck on 20, *no trips* so assumed to be pcbs so referred to hp, hp came out and replaced element & stats. just seems to have come out of normal insulation parameters i guess…
