Hotpoint Ultima DWF61 Dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Ultima DWF61 Dishwasher
  • #68893
    Cyberdog
    I have been having trouble with the dishwasher lately, so I dismantled it. There was a blockage in the Water Metering Tank, and most of the other moving parts that take water had loads of gunk in them which prevented some of them from working. I put it all together and gave it a test drive, which worked perfectly. Nice clean dishes. However I have three parts left over. These fell off when I was removing the plastic moulding from the bottom front of the machine. I have attached a couple of links to images of them, in the hope someone will be able to tell me where they should go.
    http://www.flickr.com/photos/16196946@N03/6922339012/
    http://www.flickr.com/photos/16196946@N03/7068419843/
    Many Thanks.
    The first two are not important but the small clip is used to secure the two hoses where they enter the large fill chamber and it should be refitted.
    #373085
    Cyberdog
    Re: Hotpoint Ultima DWF61 Dishwasher
    iadom wrote:The first two are not important but the small clip is used to secure the two hoses where they enter the large fill chamber and it should be refitted.
    Hi iadom,
    When you say the large fill chamber, do you mean what I called the Water metering tank, which is vertical on the left side of the dishwasher? If so does it go in between the waste outlet pipe, (on the left) and the one in the centre next to the blue fill pipe?
    Also the two bits you said are not important. Could you explain exactly where they should go, just for curiosity.
    Many Thanks.
    Dave. 😕 😕
    #373086
    The clip fits between the two corrugated hoses that fit into the far left of what you call the metering tank.
    The two small pieces come from the large front plinth, after more than 40 years I still have no idea what the purpose of them is, I have discarded loads of them in the past without any problems.
