Hotpoint Ultima Extra WMA64 – Help!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Ultima Extra WMA64 – Help!
  • #76131
    edddiec
    my HP WMA 64 started to play up yesterday – no error codes. The machine seems to fill/empty ok but the drum does not turn on either wash or spin cycles and cuts back to the normal display after about 10/15 mins. I have checked all the hose connections – they seems fine.
    Machine seems to be filling/emptying OK but will not turn the drum in wash or rinse/spin. Strange that there is no error code – if it was a broken belt or a dead motor there would be a code – right? Could it be the heater is dead?
    Any help gratefully received.
    #397352
    Re: Hotpoint Ultima Extra WMA64 – Help!
    No code, not needed anyway. All you need is to replace the worn out motor brushes by what you have told us. Check that motor! 😉
