Hotpoint Ultima FDUD43133x Fault code f06
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Hotpoint Ultima FDUD43133x Fault code f06
  • #86300
    galaxy1955
    Our dishwasher has been working perfectly until out of the blue we get the error message ‘no water supply’ and the error code f06. The water supply to the machine has lots of pressure and is clear of any debris. The machine fills up and tries to run its cycle but adds too much water which leaks onto the floor. Drain pump works fine but keep getting the error f06. What do I need to do, any help appreciated.
    #430751
    Re: Hotpoint Ultima FDUD43133x Fault code f06
    Change the water turbine/fill chamber assembly. C00256546. 😉
    #430752
    galaxy1955
    Thanks for the info. I see your’e not too far far away from me, is there anywhere local that I can buy this part?
    #430753
    No, but online direct from the Indesit Company will be as good anywhere,
    Or HERE
    #430754
    galaxy1955
    Thanks very much for your help – part ordered – should be here Friday or earlier.
    Thanks again
    #430755
    galaxy1955
    Part arrived today, easily fitted and all is now good – thanks again for your help
