Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint ultima washing machine
- This topic has 8 replies, 5 voices, and was last updated 16 years, 6 months ago by
dangerous brain.
October 7, 2009 at 3:18 pm #49160
dangerous brain
ParticipantHi there. I’m hoping you chaps could help me out here. I moved into a rental house that has its own washing machine. The agency said that the washing machine wasn’t a sustainable resource and I suspect thats because they knew its broken. Thats by the by anyway.
I’m not sure what exact model it is as there are no model details to be seen on the machine other than the ultima written on the powder tray. First time I switched it on the lock symbol continually flashed. I had a look inside and there didn’t appear to be anything major untoward so I got a replacement door lock/switch. This did’t fix it so I took out the main board. It would appear the main board is cooked. The copper wound component in the centre of the board (transformer I think) has carboning on the other side of the board to it and one of the rectangle I think its a transistor z9m y029 is blown out.
The main board is an AKO 547 352 GDA 1617204217 flash 48 956-03
Where the door lock plug goes to the motherboard there’s another slot that the plug can fit on. It looks like someone has plugged that plug on there as there is tell-tale scoring on the terminals. Now I assume that the plug should go onto the X1 terminal on the board.
Bearing in mind its not my machine is it worth a replacement main board? Where would I get one without knowing the model code? Could I just desolder the transformer and transistor and replace them as they aren’t surface mount fiddly items?
Something else thats puzzling me is that the door switch doesn’t actually appear to do anything. When manually pushed across it doesn’t bridge any terminals (the new one is the same) It only seems to do anything if you slide across the lock mechanism and then manually push the little spigot that sticks out the end which in turn locks the door mechanism. That bridges the two outer terminals. Seems a bit odd that the switch doesn’t switch anything.
Any help would be appreciated as I’d rather not have a derelict machine using up space in my house until I move.
October 7, 2009 at 7:41 pm #298919Penguin45
ParticipantRe: Hotpoint ultima washing machine
Model number is printed on the control panel and on a label on the door/hinge area.
It is the one essential piece of information required.
October 7, 2009 at 9:18 pm #298920helo_75
Participantitll be a wma
the lock wont switch till its ‘locked’
the neutral on the board will be cooked
October 8, 2009 at 11:04 am #298921dangerous brain
Participanthelo_75 wrote:itll be a wma
Ah ten points lol!! Its a WMA61.
I can understand the lock not switching until the lock is depressed but how does it output the signal to say the door is closed?
October 8, 2009 at 5:41 pm #298922helo_75
Participantit has a live.. a neutrsal and a common
door closes, swithc is activated, door locks.. feed supplied to board
October 8, 2009 at 5:56 pm #298923dangerous brain
Participanthelo_75 wrote:it has a live.. a neutral and a common
door closes, switch is activated, door locks.. feed supplied to board
I gathered it would do something like that, but I failed to find a difference in continuity across any of the 3 pins when operating manually the door shut part of the switch which I would expect to find as I’d expect the mainboard needs to know the door is shut before it tells the lock to operate.
October 9, 2009 at 1:23 pm #298924twinspark
its get its neutral through the motor 😮
October 9, 2009 at 6:42 pm #298925dangerous brain
OK well I will have to fail to understand why a switch doesn’t alter its continuity when operated lol. So does anybody know where abouts I could get a mainboard for this machine thats not going to tear my wallet in half (like I said its not even my machine) or if its ok to just solder in replacement bits like the transistor and transformer thats gone?
October 9, 2009 at 7:48 pm #298926iadom
ModeratorRe: Hotpoint ultima washing machine
dangerous brain wrote:OK well I will have to fail to understand why a switch doesn’t alter its continuity when operated lol.
Because the ‘switch’ in the door lock is only triggered when voltage is applied across the two terminals that have continuity, the slide operated by the latch prevents the switch side of the interlock from closing unless the door is closed and the latch has moved the slide out of the way.
