Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint Ultima WD865 dyer not working
- This topic has 5 replies, 2 voices, and was last updated 5 years, 2 months ago by
Isitworththehassle.
January 28, 2021 at 11:01 pm #99045
Isitworththehassle
ParticipantHi all
i Have a hotpoint Wd865 washer dryer – the dryer no longer functions and clothes come out exactly as they enter in I.e no heat is entering the dryer. I can hear the water being excavated so that seems fine, just no heat.
I had the top off and see the heater box on the top right of the drum. I have read various forums about washer dryers in general and some people suggest the TOC’s may have tripped but not clear where these are on this machine.
Any other advice would be appreciated.
thanksJanuary 28, 2021 at 11:25 pm #474832electrofix
Moderatoron the top of the dryer box should be a yellow tube. In this tube under the clamp is a protection thermal fuse
part no C00199364
https://parts.indesit.co.uk/product/washer_dryer/electrics/C00199364
they can blow for various reasons fluff build up being one of them, turning dryer off when things are hot instead of waiting till the end of the cycle
you can test it for continuity with a multimeter
January 29, 2021 at 3:12 pm #474833Isitworththehassle
ParticipantThanks dave. Let me get the cover back off and have a look. Do you know wich other parts of the heater box assembly I should check whilst I have the top off?
January 29, 2021 at 3:14 pm #474834Isitworththehassle
ParticipantAlso, i notice the link is to indesit – so hotpoint shares parts with indesit?
January 29, 2021 at 11:23 pm #474835electrofix
ModeratorIsitworththehassle wrote:Also, i notice the link is to indesit – so hotpoint shares parts with indesit?
same company so machine designs are used across the board
January 29, 2021 at 11:50 pm #474836Isitworththehassle
ParticipantThanks for the info dave. So got multimeter, opened top and as I was checking the connections for the thernal fuse noticed at one end the cable was not actually connected to its spade connector meaning the thermal fuse was only connected at one end. No idea how the cable had come out of that spade connector.
So pried open the crimp like tabs took out the copper wire, stripped a bit of sheathing of the cable and reinserted. All working fine now. very bizarre how the cable dislodged. -
