HOTPOINT ULTIMA WF860
  • #11272
    razor
    Allo all – reposted as got access to trade now 🙂 thanks dave
    any one know what fault … F-07 is on this machine
    fills for a bit then starts pumping out and screen flashes the fault F-07 .
    i,ve check motor , checked water valves aswell all ok
    also the machine actually worked other day with no F-07 fault till it stayed on 0.01 minute left to finish wash and it stayed at that for 25minutes
    anyone got list of what the fault codes mean on these models
    any help on this
    thanks
    #144591
    Dave_Conway
    Re: HOTPOINT ULTIMA WF860
    Although this machine doesn’t have the Ariston (Evo) control unit they may have adopted the fault codes.
    F07 on the Indesit/Ariston is a heater relay problem.
    I don’t know if I’m correct in my assumption but it may help ?
    #144592
    razor
    Will give it a try when back at work on monday ,
    cheers dave
    #144593
    allround
    Yes the codes are the same as Ariston . Usually ends up being a module fault (module c00099905 , eeprom 1604740) . bear in mind that its the 3 phase module which has a large capacitor , Takes approx 5-10 mins to discharge after disconnecting from electricity supply. (dont want any burnt fingers do we 😀 ) This module is used on all new ari and hpt vogue 4 1600 spin machines.
    #144594
    razor
    cheers for info there guys 🙂
