hotpoint ultima wma60
  • #45481
    ben231205
    Hello,
    I’m hoping somebody can help me with my WMA60.
    When I left the machine overnight with the door open, the drum slowly filled with water and overflowed through the door all over the floor.
    I only found this out this morning and now have an extremely wet but clean carpet in the downstairs loo.
    Is there an internal valve failing somewhere? or is this fault fatal?
    Any help would be gratefully appreciaed.
    Paul
    #285809
    Re: hotpoint ultima wma60
    If you turn off the taps to the machine and leave it overnight and no more water comes in then it does sound like a faulty valve. you will need to decide if it is the hot or cold by a process of elimination. Valves are not to expensive, well worth sorting.
    Unplug if you intend to open it up.
