Re: Hotpoint Ultima Wmud843p
Might be the actual interlock door switch ( part number C00285597 about 12 quid ), if the door does not lock. Failing that, at a guess, you could be right and the pcb could be at fault-with Hotpoint any thing is conceivable regardless of age! Do not buy the pcb and try to do it yourself as they have to be onsite programmed and in anycase your under a five year freebee parts warranty so in this case you`ll have to call them out unless you feel happy buying and trying a door lock first-at 12 quid verses a 100 quid call out for any freebee parts perhaps you should.
