hotpoint ultima wt640 washing machine, wash cycle doesnt end
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint ultima wt640 washing machine, wash cycle doesnt end
  • #86463
    newbienewbiw
    hello, the machine cycle just carries on washing for hours and doesn’t stop and when it eventually does stop the clothes are stil soaking wet, is this a common issue or do I need to buy a new one thanks
    #431831
    Re: hotpoint ultima wt640 washing machine, wash cycle doesnt
    No flashing lights or error messages?
    It doesn’t stop, and when it eventually does stop, “not logical Mr Spock” ?????
    Faulty heater can cause this, also plumbing faults causing the machine to syphon will also have the same effect.
    #431832
    newbienewbiw
    if it is the above 2 issues which were mentioned , roughly how much would it cost to repair or would it be best to purchase new one
    #431833
    Buy a new one and avoid a Hotpoint – total garbage.
    #431834
    You need to get the heating element tested for continuity, resistance and insulation.
    The heater is around £25 so well worth fixing.
    If it is due to the plumbing then there is nothing that needs fixing on the machine. 😉
