Hotpoint Ultima WT940P__Noisy
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint Ultima WT940P__Noisy
  • #72206
    underthestairs
    Hi my Hotpoint WT940P washing machine is noisy on the spin cycle….any idea why?? I have checked the drum mounting all seems ok, the machine is level, The motor looks ok as well, checked the outlet pump all clear here as well!! the machine is suposed to be supper silent…….help
    #383850
    Muv
    Re: Hotpoint Ultima WT940P__Noisy
    If its noisy only on the spin cycle…its more than likely the drum bearings are starting to wear…
    Try putting your finger at the 12 o clock position of the inner drum and lifting slightly..you may feel a bit of movement there…..
